Carb jetting/tuning???????????????
2005 Eton 90
I need help with jetting/tuning a 20mm Keihin Carb, keep in mind I have NO idea how to do this. I picked up a 20mm Keihin carb kit, exhaust and high pereformance cdi from Hetrick. I have everything installed but it doesn't run good. It starts up fine and could idle until it runs out of gas but it isn't driveable.
I don't know enough about it to tell what the problem is. It just sputters around and has no pull. Way slower than when it was stock. I don't wanna run it leaned out because I can't afford new engines. If I could get some pointers I'd appreciate it.
Turn3
Pull the plug and check it, You may be running rich ? The sparkplug is a great indicator for what is going on inside your engine.
Have you checked to make sure you do not have any air leaks ? carb to intake .... or a exhaust leak ? Start with the basics and work you way up from there.
