Wanting to peek at the clutch.... LT80
Had a question about accessing the clutch on my "new" 96 LT80. I got all the bolts out, and it seems to be loose toward the rear of the side cover but not towards the front. Tried a few gentle taps with a small hammer but it didn't pop loose. Not sure if this thing is on dowels or what and I definitely don't want to break it! Any advice?
Jeff
Jeff
Yes there are a couple "dowels" that slide in. It might take a little fussing to get it off.
If you have removed all of the bolts around the outside.......
There is also one bolt on the round cover on the face of the housing cover.
It's the bolt on the right side as you look at it.
Good Luck
Good Luck
