Kazuma Falcon 110 Wont Start !!
Just purchased a 2006 Kazuma 110 for my son. After getting it all together I went to start it and all it makes is a clicking noise at the solenoid under the seat. I do know a few things. If I disconnect the two wires running to the starter there is no more clicking. All connections have been checked and double checked. There is no power to the headlights or horn. Once again the only thing That happends is the shift selecter lights up and shows it in neutral and the clicking noise it makes from the solenoid. Please help... Thank you!![img]i/expressions/face-icon-small-disgusted.gif[/img]
Try making sure the two red power cables are attached and not just one of the red ones. Hahaha In my haste to hurry a project up accidently attached the second red cable to the (-) negative side of the battery. After fixing it and getting fuel into the carb the 110 fired up!! Now new ? it seemed to bog down when shifting into 3rd from 2nd ? And what hop up performance items can I do at home or pick up? Thanks again!!!!
Glad you got it figured out Firefightinlv, and welcome to the forum too. There is a lot of info on this forum about your 110, maybe not the falcon but lots of other chinese 110's. Lots of people have gone to a UNI pod filter or K&N's. and a few others have put FMF's universal Spark Arrester/mufflers on them too.
Originally posted by: flexikid
I had the same problem on the same atv.. it was the connection at the battery. The wire look connected but when I wiggled it the atv started. Check all connections.
TegraQuad
1) Engine problems..
13
11-26-2017 01:40 PM
