Pred 50 - How to remove rear sprocket?
Old Nov 25, 2005 | 10:32 AM
bmiliate's Avatar
Default Pred 50 - How to remove rear sprocket?
I have a 2004 Pred 50, and I removed the three bolts on the rear sprocket, but can't figure out how to remove the sprocket hub once the bolts are removed?
Thanks in advance.
Old Nov 26, 2005 | 02:47 PM
spike99's Avatar
If your Pred-50 is built like the Polaris 90 brand, then 3 bolts and some "TLC" is all that is required. For details of the Polaris 90 rear axle parts, surf:
http://www.partsland.com/index.cgi?N...EAR-WHEEL-AXLE
Sorry. the HTTP button suddenly stopped working for me. If using Windows IE, select the above string while holding down the left mouse buttom, use CTRL-C to copy, open another IE session and use CTRL-V to paste the link into the Address bar. Then, hit enter.
If you feel the sprocket is stuck (from crud), use a rubber hammer and give it a few "very small" taps. This should release it from its stuck position. Don't use more then 3 light taps at a time. If it doesn't release after 6 taps, then it must come off another way. re: isn't built the same as a Pred-90 mini.
Hope this helps - some how....
Old Nov 26, 2005 | 03:44 PM
bmiliate's Avatar
Thanks for the help!
Bratman2
Aug 6, 2022 01:42 AM
Bell21
Jul 28, 2015 06:52 AM
Sandman2.0
Jul 21, 2015 09:03 AM
tporath
Jul 11, 2015 12:31 PM
rcappie4
Jul 10, 2015 04:54 PM
