Oil in Baby falcon 110
Hey guys, I have tried reading through old posts first, but Im still a bit concerned.
I just bought a baby falcon 110 from highrpmracer.com, I read the tech tips prior to assembly, but can't figure out if the engine oil actually lubes the trans. The thing has two drain plugs, one 14mm and one 10mm spring loaded plug. I drained the large one and got about 1/2 a quart. I then replaced the oil with 20-50 and the level in the sight glass appears fine. Am I good to go, or do Ineed to replace the trans fluid? The manual says it takes both 20-50(engine) and 90w(trans), but it also says there is a dip stick and there isnt one.... Im not sure whats right. Thanks much!
There is no more gear oil used in the 110's! Only motor oil. I know the book says something else but the books were never updated! The sight glass is for the motor oil! And there is no more dip stick!
Raceway ATV Kazuma
Raceway ATV Kazuma
Njrider1230
07-29-2023 05:16 AM
TegraQuad
1) Engine problems..
13
11-26-2017 01:40 PM
