lt80 is chewing up belts....
Old Mar 7, 2006 | 03:54 AM
zmann's Avatar
Default lt80 is chewing up belts....
I got this lt80 for cheap because it would not move at all once started. The belt was broken in it. I replaced the belt and my son has probably put 10 hours or so on it and it did it again. The only thing I could think of that might be causing it is the aftermarket pull starter that is on the bike. Has anyone else had this problem?
Old Mar 7, 2006 | 07:12 PM
Makki's Avatar
If the pull starter is in the way of belt that could be it BUT
Check for condition of whole CVT + housing for wear.
Old Mar 8, 2006 | 06:01 PM
LT80's Avatar
LT80 Expert
The pull start will not be the problem unless it fell apart.
Maintenence the clutchs and you'll find the problem IMO. (Makki's on the right track) [img]i/expressions/face-icon-small-smile.gif[/img]
In the front clutch you may find rock hard grease with flat or melted rollers. The roller hub and the roller plate will be no good from nothing working properly. In the rear clutch you may have bearings bad and/or the sliding face bound up.
Breaking belts is a very unusualll thing.
Old Mar 8, 2006 | 08:57 PM
Makki's Avatar
thats right LT the problem is or the rollers,drive plate or the clutch but if you open the CVT cover you will see what is the problem/causing the belt to brake.
If the belt is braking eather he gets stuck or something rips it apart
GOOD LUCK
Bob E.
Oct 1, 2019 09:08 AM
QuadRiders
Oct 22, 2015 04:13 PM
merryman
Sep 19, 2015 03:15 AM
Jaymc
Sep 11, 2015 07:45 AM
Bergmann
Aug 13, 2015 03:51 PM
