lt80 cluth
Old Jul 23, 2006 | 12:45 PM
spendstomuch's Avatar
Default lt80 cluth
how do i get rid of clutch delayto get power to ground faster
Old Jul 24, 2006 | 11:15 AM
LT80's Avatar
LT80 Expert
Default lt80 cluth
Maybe more maintenence. [img]i/expressions/face-icon-small-smile.gif[/img]
What's it doing?
Old Jul 25, 2006 | 12:33 AM
Default lt80 cluth
it is just has a lag for about 3-4 feet when starting from a stop or getting back on a the gas has always done this since it was new are there any after market clutch kits to get power to the ground quicker
Old Jul 25, 2006 | 11:44 AM
LT80's Avatar
LT80 Expert
Default lt80 cluth
No there isn't.
Remove 2 of the 6 front clutch rollers. That should help.
I presume both carb and exhaust restrictors are removed.
Old Jul 25, 2006 | 01:36 PM
Default lt80 cluth
yes the restrictors have been removed how hard is it to take those out and can that cause any damage to the clutch or motor please forgive me i am new to this and i really appreciate your help and do you have instrructions to remove the rollers thank you for your help
Old Jul 25, 2006 | 07:56 PM
LT80's Avatar
LT80 Expert
Default lt80 cluth
There is no negative results from removing 2 rollers.
I been thinking, Lets do some checking first..I'm bothered with you stating that it's done this since you got it.
Could the carb need cleaning? Possibly a pilot jet plugged?
If all that's good, lets lower the needle a notch or 2 and see if leaning it out a lil picks up the bottom end lag.
What's the color of the spark plug? [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 25, 2006 | 11:43 PM
Default lt80 cluth
hey lt8o the carb has benn cleaned several times and the pilot looks good the plug looks dark brown on the tip i get the quad serviced every 2 races the track she races is a desert type about onemile long more of a motocross style track example of problem there is a atep up jump she can not clear it so she will back off the trottle on the take of ramp then on flat section the gives it full throttle and the quad just crawls up the face of the second part ther is about 4-5 ft flat area between take off ramp and the next hill part sorry so long winded but frustrated she does so good untill she has to let off there is just no lower end grunt gears are 12 front 26 rear she keeps good on top end they just get here out of corners and sections of track that require on and off the trottle alot
thanks for the help
Old Jul 27, 2006 | 10:53 AM
LT80's Avatar
LT80 Expert
Default lt80 cluth
Your gearing tells me that it's an older LT.
The LT is usually a grunt monster IMO.
Check the compression.
The clutchs are maintenenced every 2 races?
Old Jul 27, 2006 | 11:45 AM
Default lt80 cluth
the gearing is after market gearing that i put on and i take it to the local shop and have them check the quad out after every to races to make sure the oile is good plug is good carb is cleaned and so on
Bob E.
Oct 1, 2019 09:08 AM
QuadRiders
Oct 22, 2015 04:13 PM
merryman
Sep 19, 2015 03:15 AM
Jaymc
Sep 11, 2015 07:45 AM
Bergmann
Aug 13, 2015 03:51 PM
