klotz nitro additive for 150?
Old Aug 8, 2006 | 02:18 PM
atvmike92's Avatar
Default klotz nitro additive for 150?
Would it be ok to use this stuff in a gy6 engine? Thanks.
Old Aug 8, 2006 | 02:23 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Why would you want to? I cant tell the difference between regular and premium on mine.
Did you do any modifications?
Im pretty sure it wont hurt anything but your cash flow.
Old Aug 8, 2006 | 02:26 PM
atvmike92's Avatar
Well I read about it and it said you get a little power increase. All I have for mods right now
is a uni pod filter.
Old Aug 8, 2006 | 03:05 PM
atvmike92's Avatar
I just checked a couple sites too and the reviews all say you get an increase in power and
more rpms. Would you only notice a differance in rpms if you had a tachometer?
Old Aug 8, 2006 | 04:33 PM
KTM Patrol
Former Chinese POW!
I would think its advertising BS. There is no way to get a engine with a rev limiter to rev higher by just adding something to a gas tank. Do you run premium fuel in it now?
Old Aug 8, 2006 | 04:59 PM
2manytoys's Avatar
The klotz additive is for higher compression motors while useing a lower octane fuel.
Old Aug 9, 2006 | 02:05 AM
Doctorturbo's Avatar
GOT BOOST!
You can use it and you will pick up quite a bit of power. Nitropropane is nasty stuff. You will really have to be on your game jetting wise. This stuff is an ox fuel just like nitromethane with a different base.
If your jetting is off, even just a bit with that much O2 in it your going to burn it down..........and quick!!!! Just like N2O you better have an idea what your doing.
Old Aug 9, 2006 | 05:12 PM
atvmike92's Avatar
No I run super unleaded in it. And by too much o2 do you mean the engine will blow? Thanks
for the replies.
Old Aug 9, 2006 | 05:21 PM
KTM Patrol
Former Chinese POW!
Do you really think he will notice a difference in a stock Gy6 engine? I could believe it in something modified, but this is basically a stock scooter engine.
Old Aug 9, 2006 | 05:22 PM
KTM Patrol
Former Chinese POW!
for the replies.
I think he means it will melt down from excess heat and put a hole in the piston.
