Eton Vector 250
Old Dec 6, 2010 | 04:17 PM
  #21
check's Avatar
Never make a decision before you have to, always have a Plan B, and don't tell me it's not possible!
Thanks, LynnEdwards, I'll check that out when I am up next.
Old Jan 2, 2011 | 02:50 PM
  #22
check's Avatar
Originally Posted by LynnEdwards
The quad should be able to hold its own with the engine running. The battery charge system should be able to (on average) run everything - including the head lights - and still keep the battery charged. I suspect your charging system isn't working. With the headlights off and the the quad running at medium fast speed, measure the DC voltage right on the battery terminals. It should read 13.5 to 14.5 volts. If it does your charging system is working. If it doesn't read within that range the charging system needs looking into.
LynnEdwards, I tried measuring the Eton Vector 250's voltage when the engine was running, and at first I got up to 14.5 or so, but then later I only got a max of 13.39, and the machine was running rough at that point. As well, both the battery and a 300 amp booster battery that I hooked up in parallel went down to 12.5 volts or less. The ATV battery I can explain as a bad battery that won't tolerate a load (even though I can charge it up to 13 volts). However, I did not expect the booster's voltage to drop like that. (It is a rechargeable booster which I had charged up to 13 volts prior to this little test.)
So now it appears that there is an intermittent problem where the stator sends out 14.5 volts sometimes and only 13.4 volts at other times. How is this possible? As well, even with the booster attached, the system will sometimes go dead and then come alive again when you turn the key off and then back on. And how can an ATV that is running and putting out 13.4 volts then run down a 300 amp car booster, down to the low 12's?
Aaaargh!
Old Jan 3, 2011 | 11:18 PM
  #23
LynnEdwards's Avatar
Electrical Expert
My text embedded in red:
Originally Posted by check
LynnEdwards, I tried measuring the Eton Vector 250's voltage when the engine was running, and at first I got up to 14.5 or so, but then later I only got a max of 13.39, and the machine was running rough at that point. [The output of the stator is dependent on engine speed. If the stator is heavily loaded, or if the engine is spinning slow, the stator (along with the voltage regulator) may not be able to keep up. The excess needed power will be drained out of the battery. But at speed the engine is spinning faster and putting out more power. You don't need the stator to keep ahead of the needed power all the time - it just needs to be able to provide charge current to the battery on average. That is why the battery voltage test is done with headlights off, and at a medium fast engine speed.] As well, both the battery and a 300 amp booster battery that I hooked up in parallel went down to 12.5 volts or less. The ATV battery I can explain as a bad battery that won't tolerate a load (even though I can charge it up to 13 volts). However, I did not expect the booster's voltage to drop like that. (It is a rechargeable booster which I had charged up to 13 volts prior to this little test.) [A good battery when not being charged reads 12.6 volts. Sometimes right after being charged it read slightly higher, but after drawing even minimal power of of it it returns to 12.6 volts. Then as more and more power is pulled out of the battery the voltage slowly droops from there.
I'm not sure what your "300 amp booster" is. Some boosters just dump a ton of current into the battery to help out a sluggish starter in a car or truck. You can get away with this on a car since the battery is physically huge and can take short term abuse like this, but your teeny quad battery cannot. It is possible that the booster supply puts out current only if the battery voltage drops below 12 volts, but that would be a more complicated design so the skeptic in me says this ain't so. I would be very hesitant hooking up a boost anything designed for cars to a little quad battery. A quad battery should never be charged at more than 2 amps.
Try this: Disconnect your bad quad battery. Use a pair of jumper cables to hook the quad battery wiring up to your car (be extra sure to get the polarity right). Leave the 300 amp boost whatever on the shelf. Start up the quad and do the voltage measurement at a medium fast engine speed]. With the bad quad battery and the mystery boost thing out of the way are you able to see the charging system putting out 13.5 to 14.5 volts? What I'm wondering is if the bad quad battery itself is what is loading down the charging system. I'm making the assumption that your car battery is in good working order and charged up. A fully charged car battery should easily be maintained with the small quad charging system, and you should get the 13.5 to 14.5 volts at the car battery.]
So now it appears that there is an intermittent problem where the stator sends out 14.5 volts sometimes and only 13.4 volts at other times. How is this possible? As well, even with the booster attached, the system will sometimes go dead and then come alive again when you turn the key off and then back on. [I'm not undertsanding this. What is meant by 'going dead'? Lights and starter quit working at all? Or does it mean that you're going from 14.5 volts to 12 point something volts?] And how can an ATV that is running and putting out 13.4 volts then run down a 300 amp car booster, down to the low 12's? [Again I don't know exactly what your 300 amp supply is doing. 300 amps scares me a bit. Let's get the unknowns (the boost supply and the bad battery) out of the picture and look at just the quad charging system using your known good car battery.]
Aaaargh!
Old Jan 4, 2011 | 06:24 PM
  #24
check's Avatar
Hey, thanks again, LynnEdwards - you have given me a ton of ideas, and in fact maybe also provided a potential explanation for why we have also had problems with my daughter's Arctic Cat 150 battery (namely, the booster). Will try using an ordinary car battery like you suggested, and see what happens.
One additional worry has to do with the "cutting out" that I mentioned previously. What happened this weekend was that, while I was trying various things, I would intermittently get the whole system on the Eton Vector shutting off as if there were no battery at all. (No electronic display, nothing.) The I would try turning the key off and on, and wait a bit each time, and then eventually the display would light up again and sometimes there would even be enough power to crank and start the engine. Or, I might get the electronic display lighting up, but only get a clicking/buzzing sound when I tried cranking the engine. (Thus I suspect something might be loose or have a bad connection.) But of course I will have to try it again with a car battery as you suggested, which will not run down right away like the little quad battery did.
May go up again this weekend to try this out. Will keep you posted.
Thanks again - you have been a great help!
Old Jan 5, 2011 | 07:38 AM
  #25
check's Avatar
BTW LynnEdwards, the instructions for a new (9AH) battery I just bought for my daughter's Arctic Cat 150 say that the battery should read 13 volts when fully charged, and that 12.8 is only 75% charged, and I believe that 12.5 or 12.6 is only 50% charged, so perhaps the 12.6 volts that you suggested in your last post varies as a function of the manufacturer and/or size of the battery? (The Eton Vector battery I believe is a 12AH battery.)
Also, the weird part is that none of the Vector problems were happening until after the ATV had been running for a while (a good 15 minutes or so), and even then if I could coax it to run after the problems started I could usually keep it going if I was driving around at speed. It would then just die and give me grief if I stopped and/or let the engine slow down to anywhere near idle speed.
Old Jan 5, 2011 | 11:55 PM
  #26
Electrical Expert
BTW LynnEdwards, the instructions for a new (9AH) battery I just bought for my daughter's Arctic Cat 150 say that the battery should read 13 volts when fully charged, and that 12.8 is only 75% charged, and I believe that 12.5 or 12.6 is only 50% charged, so perhaps the 12.6 volts that you suggested in your last post varies as a function of the manufacturer and/or size of the battery? (The Eton Vector battery I believe is a 12AH battery.)...
It doesn't make sense to me. A lead acid battery produces 2.1 volts per cell. A 12 volt battery uses six cells stacked up together to make 12.6 volts. The voltage is also not a function of the size of the battery. A 200 amp-hour bulldozer battery should be the same voltage when fully charged as your car battery, and also your quad battery. There are a lot of things I don't know (I'm learning every day), but I've never heard of a 13 volt lead acid battery that is 50% discharged at 12.6 volts.
...Also, the weird part is that none of the Vector problems were happening until after the ATV had been running for a while (a good 15 minutes or so), and even then if I could coax it to run after the problems started I could usually keep it going if I was driving around at speed. It would then just die and give me grief if I stopped and/or let the engine slow down to anywhere near idle speed.
I just downloaded the vector 250cc wiring diagram today. Like most published diagrams it mostly unreadable, but I do see that your ignition system is powered off the 12 volt power bus (unlike many quads). If your charging system isn't working and your battery goes dead after 15 minutes of operation, the quad will quit running too as the spark gets weaker at low RPMs. If this were the case the battery would be so dead after the quad dies that the starter motor wouldn't have enough power to crank the starter again. Another thing to try: When the engine starts to falter at low RPM's, turn on the headlights. If that kills the engine dead then there you go... But if the headlights light up bright and the engine runs the same then you have other problems.
Old Jan 6, 2011 | 09:09 PM
  #27
check's Avatar
Thanks again, LynnEdwards - will try it when I am up next. Sure hope it's just a crappy battery!
Old Jan 14, 2011 | 12:04 AM
  #28
check's Avatar
LynnEdwards, it turns out that the existing the battery will no longer hold a charge (I just got a buzzing sound even though it was charged up to over 12.5 volts, but then it immediately dropped down to 11.5 or so), so I substituted a 20 AH battery from another ATV, which worked fine and did not die when the ATV lights were turned on. I drove the ATV around for quite a bit, until the old problem started again, and then I measured the 20 AH battery while running - just over 14 volts (even at idle), so the stator seems fine. However, I still got the same old problem, where it starts to stutter, but only after driving it for a while (but not after letting it sit idling, even if it is for a long time.) As well, if I shut it off and let it rest for even 5 minutes, the problem goes away until after I drive it again for a bit.
I also tried using the booster as a battery, and that worked, but I did get some buzzing like I get with a bad battery when trying to start it sometimes, but if I try again and again the starter will eventually catch. (Also, when I got the buzzing sound with the booster I measured the voltage right away and it was still up to 12.6 or so, suggesting that the problem might be with the circuitry, and intermittently so.)
I am bringing the ATV down to Toronto with me tomorrow to play with it some more, but in the meantime I am stumped, and at this point I am afraid it might be some intermittent electrical problem that will be very difficult to diagnose.
Old Jan 14, 2011 | 11:22 PM
  #29
Electrical Expert
My comments embedded in red:
LynnEdwards, it turns out that the existing the battery will no longer hold a charge (I just got a buzzing sound even though it was charged up to over 12.5 volts, but then it immediately dropped down to 11.5 or so), so I substituted a 20 AH battery from another ATV, which worked fine and did not die when the ATV lights were turned on. I drove the ATV around for quite a bit, until the old problem started again, and then I measured the 20 AH battery while running - just over 14 volts (even at idle), so the stator seems fine. [That means the battery charging portion of the stator is working, but does not necessarally the Ignition trigger coil] However, I still got the same old problem, where it starts to stutter, but only after driving it for a while (but not after letting it sit idling, even if it is for a long time.) As well, if I shut it off and let it rest for even 5 minutes, the problem goes away until after I drive it again for a bit. [What happens if you let it sit for 30 seconds? Are you sure your not running out of fuel? The classic symptom of a plugged fuel filter (or any other cause of slow fuel feed) is just what you described. Everything runs fine at any time the fuel consumption rate is less than maximum. Then at speed the carburetor gets behind, runs dry, and falters. You stop for a bit and the slow fuel drip fills the carburetor back up and off you go again. Do you have a timing light? You could hook that up and drive around with it. When the engine starts to falter pull the trigger to see if the strobe is going off regularly. That will tell you if you are losing spark or not. This is a bit of a difficult test. When the engine falters the engine speed will be variable, and will produce a variable timed spark. What you need to see if you can determine is whether the spark is missing when faltering or just variable timing. This is a tough call. It is worth trying though. The goal is to determine if the engine is faltering due to electrical problems or fuel problems.]
Old Jan 15, 2011 | 07:46 AM
  #30
check's Avatar
Actually, when the problem occurs the ATV will still run fine at full throttle, IF I can get past that initial jerkiness by feathering the throttle off the line. And when I say jerkiness, I don't mean bogging (although that will occur if I push the throttle too far off the line). What happens is a very violent jerking, as if it was going in and out of gear - so violent that I become afraid something will break. (I will have a look at the fuel filter, though.)
I spoke to an Arctic Cat dealer who had a Can-Am 250 trade-in with a similar problem (no surprise, since Eton apparently makes the 250 for Can-Am), and he said it was likely either the spark plug (easy to check), the coil (relatively cheap to replace), or the CDI (more expensive). He also said there is gearing electronics downstream of the (mechanical) gearbox which could be at fault, but I didn't catch exactly what it was. As well, he thought that the fact it only occurred after riding a while was diagnostic, since a lot of electronic failures occur only with heat.
Anyway, I have it with me here in Toronto now, and I will get a new spark plug and have a look at the old one. I also emailed the Eton Canada Dealer in Alberta, and will call Switzer Motors here in Toronto (where I bought the ATV) again, to tell him it is NOT an old gas problem, and see if he has had any problems with other Vector 250s.
Also, I will see if I can get a timing light and rig it up as you suggested, but that may take some time.
