2007 kfx 90 need help speed limiter
there is a small ring in the CVT variator clutch, take off the left footwell, remove the clutch cover bolts (8), remember where the one small one goes, then you will need an impact wrench, 17mm socket, hold the clutch with your hand and remove the nut, remove the outer sheeve and take out the thick "wedding ring", this ring is stopping the sheeves from coming together, you will get approx 7-10 more MPH out of it
If i am right the new kawa 90 is made by kymco.
Just bought a kymco 90 for my son and one of the restrictions is in the CDI unit and the other is a ring on the clutch CVT. I unrestricted just today the one on the CDI. There are two connectors on the CDI ,one with 4 wires and one with 2 wires .Both connectors have a light green wire, you just cut the light green wire on the 4 wire connector . NOT ON THE 2 WIRE CONNECTOR .It drove alot faster, i still have to remove the one restriction on the CVT.
My friend have a paper with the instructions how to remove that and can post it here later.
Make sure the kawa is the same as the kymco, i think it is , i heard kymco is making some atv for kawa and other brands.Check there is on the kawa CDI are the light green wires on a 4 and 2 wire connector.
Hope this will help you.TextTextText
