Can't get it started!
Old Sep 8, 2006 | 01:57 PM
300exBirddog's Avatar
Default Can't get it started!
That is what someone else said to me. So I guess I will go from there. Thanks for your help.
If you think of anything else, give me a yell.
Old Sep 8, 2006 | 05:07 PM
JD4020's Avatar
take a look at this thread.... http://forums.atvconnection.com/mess...&keyword1=woes
I had the same problem and this took care of it.. I have also forwarded a few other folks to this thread and it also helped them..
Good luck.
If the thread doesn't work, do a search for "carb woes"
Later,
Jon
Old Sep 10, 2006 | 12:08 PM
sssduane's Avatar
I had 45 psi on my 90 and it wouldn't tart, yanked the jug and the rings and piston was shot. You should definetly have over 100 psi.
Old Sep 11, 2006 | 09:02 AM
I did some messing w/it this weekend. Took a look at the timing. It appears that it is firing on the down stroke. I do not see any place nor way to make a timing adjustment. I noticed some kind of module or what not that the madgnito wire goed to w/5 other wires. A pair of these go to the coil. I do not know what it is and would think this is the culpret?
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
