Mini Falcon 90
Old Sep 19, 2006 | 02:38 PM
brettmoran's Avatar
Default Mini Falcon 90
Just ordered from High RPM. Besides changing the oil (oil reccomendations?), what do I need to do when I get it?
Old Sep 22, 2006 | 03:14 PM
brettmoran's Avatar
Just starting reading this forum. Sounds like I should have ordered from Raceway. [img]i/expressions/face-icon-small-sad.gif[/img]
Old Sep 22, 2006 | 10:32 PM
2manytoys's Avatar
High rpm not a good place to buy from. Hopefully you get it and nothing is broken.
Old Sep 23, 2006 | 11:13 PM
brettmoran's Avatar
Got it put together today and everything seems fine. The plastics are a little disappointing; the back left fender sits way higher than the right.
Do I need to oil the chain?
And looking at the back, on the left there is a clear resorvoir with some type of fluid in it. What is this?
And what is the the correct amount of oil the engine needs; there are two numbers in the manual; one for diff and the other for engine; it only seems to need about 1/2 a quart.
Old Sep 24, 2006 | 10:03 AM
billl2099's Avatar
get some chain lube at any m/c shop or wal-mart has it, the fluid is brake fluid for the rear disc brake, you can use 10-30, 15-40,20-50 all depending what the tempueraure where you live. the engine and transmission shears the same oil
Old Sep 25, 2006 | 11:21 AM
SEADAWG's Avatar
You get the same ATV regardless of who you buy it from. The difference is the service after the sale and that is why Raceway has this market cornered. Raceway needs to go to China and change the quality issues the plague these poorly made quads. SEADAWG
Old Sep 25, 2006 | 11:23 AM
brettmoran's Avatar
And apply oil to the chain?
Old Sep 25, 2006 | 11:25 AM
brettmoran's Avatar
Well, I've probably been lucky so far. Aside from the fender issue, it seems OK. But the whole time I've been uneasy about not knowing anything about who I ordered it from; wish I would found this group before I ordered. Will definitely use Raceway next time.
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
MrTrashMan2U
Sep 9, 2015 11:44 AM
