Kazuma 150 chain rubs
Old Nov 8, 2006 | 08:10 PM
  #21
Noxzema's Avatar
Default Kazuma 150 chain rubs
thanks for the post smb05.
Yes, it has rubbed since new. This is my second 150. The first one rubbed also but i only had that one for a month before i returned it because of a main bearing seal leak.
It has progressively dug deeper into the frame. I will check the shock mount. I have not put it up to what the wheels run, i was thinking of that but have not done it. I just think this whole issue is a bad design issue. It's was simply positioned too near the frame. The chain slapps around killing the frame etc. It's a grease factory around my chain. AHH that is why i love shaft drives!
The PVC idea is excellent and i will probably use that as a quick simple fix!
Old Nov 9, 2006 | 08:16 AM
  #22
bakermon's Avatar
smb05,
I would like to see a picture of your pvc protector if you have time. I won't be able to do anything till after T-day. Mine isn't real bad but i would like it to be better.
Thanks tim
Old Nov 9, 2006 | 06:39 PM
  #23
smb05's Avatar
bakermon,
I up loaded the pics just waiting for approval. When my camera icon comes back just click on it. Look at the last three pics.
SB.
Old Nov 9, 2006 | 07:48 PM
  #24
SEADAWG's Avatar
My Falcon Adult 250 rubbed from the get go and was bad. The VX-80 didn't start rubbing until the second time out in the woods beating it up. Hope that helps. Also, on my 250, the tentioner flipped around while I was on the trails and dug a hug hole in the swing arm. I just don't think the spring was built trail ready...very soft. SEADAWG
Old Nov 10, 2006 | 07:39 AM
  #25
bakermon's Avatar
smb05,
Thanks for the pics. My dingo is rubbing an upright tube and a little of the gear box. If I can move the sprocket slightly to the right then I will be ok to put the pvc on the frame tube. Where as yours seems to be hitting from on top of the chain , mine is hitting on it's side.
Thanks again
tim
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
strokesb16b
2) Chassis problems..
Sep 15, 2015 09:19 PM
bmark0610
Sep 7, 2015 09:42 PM
