Reverse Trans on the 150's?
Old Jan 9, 2007 | 08:43 PM
outofline's Avatar
Default Reverse Trans on the 150's?
I guess there are the two types, the Rear axle and the front style (I'm not sure how that is set up).
I am guessing the front type is the best? which brands have this transmission? Are the rear boxes durable, it seems there has been many problems with them and a old weaker gear in them. Do the front type have problems?
Old Jan 9, 2007 | 09:09 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
The rear reverse has a few problems. The biggest problem is its weight. It really affects the handling/suspension of the quad. I have had no mechanical problems with mine, but I drained out the stock gear oil. (2ozs) and put in 8ozs of 90wt gear oil. I have not seen the new reverse yet but moving it to the engine has to be a much better idea.
Old Jan 9, 2007 | 09:26 PM
godIlove2ride's Avatar
Mine is by the engine and it shifts flawlessly, and knock on wood, no issues after 7 months.
Old Jan 9, 2007 | 09:52 PM
2manytoys's Avatar
I have a JetMoto 150 with the reverse gearbox on the rear axle. I have not had any problems with it. It actually works pretty well. I did change the gear oil once I got it. I do think that if it is not adjusted properly and enough throttle is applied it will break. Mine gets ridden pretty hard and no issues with the gearbox so far.
lonerider856
Oct 13, 2023 03:45 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
poutlaw525
Sep 9, 2015 03:19 AM
