Grease nipples on Giovanni quads
Old Mar 8, 2007 | 09:05 PM
mrj's Avatar
mrj
Default Grease nipples on Giovanni quads
Just purchased a 110 giovani for my 8 year old. I havent got it yet in shipping. Just wondering how you made out with it and any problems with the dealer on ebay
Old Mar 9, 2007 | 08:26 AM
falco2033's Avatar
I didn't have any problems so far. I did the following so far just from reading stuff on this forum:
1. changed crankcase oil before I even fired it up(used 10W40 atv oil).
2. changed the plug to an NGK one
3. checked and changed oil in the reverse gearbox. There was hardly any oil in it. Not near enough.
4. changed oil in the CVT (transmission). used 75W90 gear oil in the transmission and the reverse gear box.
5. went over all the nuts/bolts and checked for tightness. Some were loose.
6. changed the grease fittings on the front end. The original ones are some wierd size(not standard 1/4 ")
You'll find that their won't be any instructions for putting stuff together but it is pretty straightforward.
I bought my son the 150 and it has a GY6 engine. I assume the 110 will also.
If you search this forum, you will find links where you can download manuals of other vehicles that use the GY6 motor.
PM if you have any other questions.
Old Mar 9, 2007 | 09:37 AM
billl2099's Avatar
the 110 is a completely different engine than the gy6, gy6, only comes in a 125 and a 150cc, the 110 is in the same family of the 50,70 and 90cc. do make sure to change the shipping oil , can use eaither 15-40 or 20-50.
Chillibean
1) Engine problems..
Sep 5, 2020 04:02 AM
Frisky2050
Apr 9, 2020 11:19 AM
toonces
Jul 28, 2015 01:58 PM
Sandman2.0
Jul 21, 2015 09:03 AM
ranvette
Jul 4, 2015 06:13 PM
