Kazuma 90 noise and will not stay running
Old Apr 14, 2007 | 08:33 PM
cowgirl's Avatar
Default Kazuma 90 noise and will not stay running
It just quit running, adjusted the valves and it still sounds really bad and does not want to keep running it sounds like the noise is comming from the left side, anyone have any ideas? thanks
Old Apr 15, 2007 | 10:28 AM
2manytoys's Avatar
What kind of noise is it. Did the exhaust bolts come loose? I have seen the exhaust come loose on them and it will cause it to run bad.
Old Apr 15, 2007 | 12:05 PM
cowgirl's Avatar
It sounds like the noise is coming from the left side of the motor, like a loud ticking noise or light rapping noise
Old Apr 15, 2007 | 12:08 PM
2manytoys's Avatar
How old is the quad and are you sure you adjusted teh valves right. It has to be at top dead center. Ticking is usually valves. What oil do you use and did you adjus the idle screw up.
Old Apr 15, 2007 | 01:02 PM
smb05's Avatar
cowgirl,
Like 2manytoys suggested check exhaust bolts, readjust your valves. Also you may want to check and readjust your cam chain tension. If it is out of adjustment it will make a tapping to rapping noise.
Good Luck.
SB.
Old Apr 15, 2007 | 04:43 PM
cowgirl's Avatar
How do I adjust the cam chain tensioner and the atv is about 1 yr old, I use 20-50 oil. thanks
Old Apr 15, 2007 | 05:01 PM
smb05's Avatar
Look here : Cam Chain Adjustment look towards the bottom of the page.
Good Luck
SB.
Old Apr 15, 2007 | 06:31 PM
cowgirl's Avatar
I am really green when it comes to working on these atvs, do they show a picture to do this adjustment? I read the how to. Thanks
Old Apr 15, 2007 | 07:43 PM
smb05's Avatar
Here you go. Cam Chain Adjustment
Honda engines produced after 1984 had an automatic tensioner installed in the engines. If yours is the auto type you may want to inspect the tensioner for any worn parts.
SB.
MikeyBoyesq
Nov 27, 2020 02:44 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
jayking232003
Jun 9, 2015 02:54 PM
winterwolf
ATC 3-Wheelers
Jun 3, 2015 07:34 PM
cornermike
May 27, 2015 10:04 PM
