Wheel Spacers
Old May 3, 2007 | 04:00 AM
TriplxX07's Avatar
Default Wheel Spacers
Here is a picture of the wheel spacers I made for my son's atv.. I used 4 inch long 5/16 grade 8 bolts/locking nuts, and 3 inch pipe for the spacer.. All can be bought at your local Hardware store for under $20.. Then I recently threw some paint on the spacers to match the color of his atv..
Click for picture
Old May 3, 2007 | 10:33 AM
billl2099's Avatar
their you go guys, TriplxXO7 has it with the exception that i installed another nut and washer at the end of the spacer to keep it in place when the wheel removed, also i would reccommend using 10.9 -14.9 grade bolts. i purchased 10.9 grade 8x1.25mm bolts and 10.9 grade nuts from boltdepot.com, the spacer rod i purchased from home depot and use a tubing cutter to cut it to lenght, then measured them to make sure they were all within .010 of each other,the ones i made are 2 years old now and we never had a problem with them, i added 2" to each side for a total of 4", these work go for kids 50-90cc atv's and cannot reccommend doing this for an adult quad, for the 110cc atc i used 7/16 bolt which threads are almost the same as the 10x1.5mm hub, and installed them from the back side of the hub into 7/16 threaded rod connectors, then used a 7/16 bolt for the lug bolt, this adds appox 1.5" to each side for a total width increase of 3".
Old May 3, 2007 | 02:45 PM
tencubed's Avatar
Being retired is a hoot!
Thanks fellows for the good idea. Gonna save a lot of money for several folks. [img]i/expressions/face-icon-small-smile.gif[/img]
Old May 5, 2007 | 08:30 AM
falco2033's Avatar
Click for picture
Bill, could you do this for a 150 too?
Old May 6, 2007 | 12:02 PM
  #15
illin's Avatar
I would only do a "bolt style" spacer on a kid quad. Anything bigger or with an adult on board needs a solid spacer. You could have someone make one quite easily.
The bolts work, bu the will put allot of stress on the hub.
I would also add that you should use flange style bolt as this effectively doubles the contact area with the hub.
Old May 6, 2007 | 03:55 PM
  #16
Guest
Guest
Posts: n/a
billl2099,
me too. can you email me the spacer plans.
thanks
pedez2000@yahoo.com
Old May 7, 2007 | 12:34 PM
  #17
abramsgunner's Avatar
I did the $12 longer-bolt-extra-nuts-wheel spacers on my daughter's sunl mini 110... huge improvement and cheap. I wouldn't trust it on a larger quad, or with a heavier rider (she's like 50 pounds or so), but on a small quad that is used for running the dirt trails at less than 15 mph... best money I spent so far (besides the helmet, goggles and gloves... grin)
Old Jul 12, 2007 | 01:09 AM
  #18
tony_35_1969's Avatar
We have a 90cc sunl and we would like to know how to make spacers for it .
Old Jul 12, 2007 | 01:12 AM
  #19
forgot to put my e-mail,
tony_35_1969@yahoo.com
Old Jul 12, 2007 | 05:39 PM
  #20
i was going to see if you got my e-mail?
about the 90cc sunl 4-wheeler?
we would like to know how to make our own spacer
