Fushin 110cc ATV
Old Jun 9, 2007 | 09:03 PM
hollinjes's Avatar
Default Fushin 110cc ATV
Bought one of these today for my son, but can't seem to figure out how to get it started. Can someone help out a single mom who doesn't have a clue???
Old Jun 10, 2007 | 12:05 AM
illin's Avatar
First, make sure the gas is on...it is a petcock that is located under the tank.
Next, turn the choke on (see the manual for that). Turn the key on.
Hold the brake on, press the starter button and give it a little gas...it should fire up.
The only tricky part is making sure you are getting gas...sometimes the Chinese confuse on/off and they are reversed.
Old Jun 10, 2007 | 02:59 AM
jr warren's Avatar
I work on them everyday setting them up for customers you need to drain the carb bowl,the bottom screw on carb there is a small hose besides it that is just running to the bottom fill with gas loosen the screw and let the carb drain the gas stabelizer out about a shotglass full .the screw is on the bottom besides the hose make shure to check the kill switch on left handlebar put it in the center and push it in it should click pull brake lever and lock it don.t touch the throtle untill it starts on its own about 3 trys they normally start
Bratman2
Aug 6, 2022 01:42 AM
wrencher82
Sep 28, 2015 10:02 PM
DanP24
1) Engine problems..
Aug 12, 2015 11:39 AM
Waddell4436
Jul 20, 2015 09:46 AM
