Baja Wilderness 250
Old Aug 8, 2007 | 03:40 PM
CWESTE's Avatar
Default Baja Wilderness 250
I have a Baja Wilderness 250 and have had alot of fun with it. However, since new it makes a loud "clacking" sound from around the head of the motor....especially when under hard aceleration or load. Could this be just valve noise? are these motors know for such clacking sounds or should i start paying closer attention? Should be noted it does not leak or burn any oil and probably has 800 km on it now.
Anybody else hear this on their 250?
Old Aug 10, 2007 | 09:18 PM
fullup's Avatar
I have the same noise with my Baja 250. I have adjusted the valves and the noise is still there. I am sorry I can't help you but if I find out I will post it up for you.
Old Aug 10, 2007 | 11:11 PM
CWESTE's Avatar
Thanks i appreciate it. I adjusted the valves too with no luck.
Old Aug 11, 2007 | 01:21 AM
SilveradoSS's Avatar
Someone here will need to jump in to confirm/give advice, but I remember reading somewhere that this type of noise sometimes comes from the cam chain due to a tensioner problem.
Old Aug 11, 2007 | 09:54 AM
CWESTE's Avatar
Great thanks, do you know anything about the consequences of this potential problem? Am i doing damage to the machine by riding it as is? I do alot of trail riding in Northern Ontario and if it breaks down out in the bush...its not coming home....ever.
Old Aug 13, 2007 | 10:44 AM
billl2099's Avatar
their's a cam chain adjustment on the side of the clyinder, stickes out about an inche and a haft , has a bolt and lock nut on it, to adjust loose the lock nut and tighten the bolt until the noise is gone then retighten lock nut
Old Aug 13, 2007 | 03:17 PM
CWESTE's Avatar
Great i know exactly where it is..ill give it a try and see what happens.I wouldnt call the machine chinese junk...but my next one will be honda or an arctic cat.
Old Nov 1, 2011 | 12:00 AM
HEBTEXAS's Avatar
wondering if it was fixed?
akguy31
Aug 31, 2019 04:34 AM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
Elkaholic
Sep 6, 2015 02:44 PM
