HELP!!!! No Spark
Old Sep 4, 2007 | 11:09 PM
jake100's Avatar
Default HELP!!!! No Spark
OK I've tried 3CDI boxes ,2 Stators, 2 Coils, 2 Spark plugs all safety switches check out and still no spark !!!!!!!!!!!!!!!!!!! HELPPPPPPPPPPPPPPP Thanks JK
PS it has had the remote start stuff removed
PPS it' a FUSHIN 110
Old Sep 4, 2007 | 11:26 PM
SilveradoSS's Avatar
Was it running before the remote start was removed?
Old Sep 4, 2007 | 11:49 PM
komatzu's Avatar
Do you still have the remote box. If you do hook it back up and see if you get spark. On some chinese bikes with remote kills if you unhook the box they will not start. You can unhook them but you need a wiring diagram to see what wires you need to jump together to complete the circuit.
Old Sep 5, 2007 | 12:02 AM
jake100's Avatar
No I don't have the remote box, it came that way, not running. I have a diagram of similar machine and the wiring seems to check out color match, contunity etc. etc. I'd assume that these are rather genaric. Could the rectifier/regulator cause it??? It looks to like all the key switch does is to actify the starter circuit/ lights and kills the ignition. Thanks JK
Old Oct 12, 2007 | 10:33 PM
jpotts's Avatar
hello, did you ever find out what was wrong with your 4 wheeler? i have two that are the same way.
Old Oct 12, 2007 | 11:08 PM
jake100's Avatar
I finally got it running. I did so much stuff I'm not sure what really fixed it. I think that the pins in the CDI plug were not making a good connection. you might check All the connectors. I ended up cutting the plug apart and closeing each connector up so that it was a good fit then lightly siliconed the whole mess together. Good luck JK
Old Nov 29, 2007 | 07:52 PM
garyseltz's Avatar
Hello i wanted to know if u can help me out with something i need a wiring diagram for this 70cc quad i am working on, the one u talked about might help me out
garyseltz@yahoo.com
Old Dec 3, 2007 | 09:47 PM
jake100's Avatar
This is a link to site about the CDI box which you might work for you. On mine I think it was actually the connector that wasn't making the trip JK
http://www.btinternet.com/~jhpart/bkns125a.htm
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
