very hard starting
Old Dec 7, 2007 | 04:46 PM
onebigzj's Avatar
Default very hard starting
now that I got the other problem fixed. I thought my long cranking time to start would be fixed. basicaly when hot starts right up. but when cold it takes whole battery and a charger/starter to start. with or with out choke doesent matter. any ideas? both my lt80's have the same problem.
Old Dec 9, 2007 | 11:47 AM
onebigzj's Avatar
I guess Im on my own. thanks
Old Dec 9, 2007 | 11:55 AM
outofline's Avatar
Those of us who don't know the other problem have know idea what you have had to do til now so it's hard to suggest any thing, care to elaborate more?
Old Dec 9, 2007 | 12:14 PM
onebigzj's Avatar
all new top end, new clutch. dun when cold takes forever to start. wears battery down and I have to hook up starter box( battery charger on start mode) then will come around and fire. once started and still warm will kick off fast. once cooled get the starter box out. carb is clean as a wistle.
Old Dec 9, 2007 | 12:32 PM
YZOtis's Avatar
Since you disconnected the oil injection are you leaving the fuel valve on prime? Is there excessive smoke when it does start? Wonderin if fuel is seeping through the carb into the case when it sets for awhile. Makes things rich, wets the plug & hard to start. Just a thought [img]i/expressions/face-icon-small-smile.gif[/img]
YZ Otis
Old Dec 9, 2007 | 02:00 PM
onebigzj's Avatar
no excessive smoke! I thought the same but plug is dry before start up. pulled the plug 1/2 way through starting procedure and is still dry. tryed on prime to see if petcock was screwed still doesend get wet. have to choke and hold on gas to get started. after way to much cranking.
Old Dec 9, 2007 | 02:17 PM
hoytultratec's Avatar
you might need to adjust the needle setting on the carb
Old Dec 9, 2007 | 02:22 PM
onebigzj's Avatar
its at 2 right where the manual has it.
read through 2manytoys write up it works...read the cold weather part this could help.
Old Dec 9, 2007 | 02:24 PM
dont worry about the manual they have to be adjusted for the temp sometimes..give it a try.
