Adjusting JetMoto Carb...
Old Dec 12, 2007 | 08:00 PM
biskit134's Avatar
Default Adjusting JetMoto Carb...
Hey guys, the only screw that can be adjusted on the outside of this carb is the idle speed screw with the spring around it. Can anyone tell me how to adjust the air/fuel mixture without rejetting? Seems to be running a tad lean as it has a "flat spot" in first gear. Seems to pull fine in 2-4, but I can feel that it wants a tad more fuel... thanks...
Oh, for those of you that might need a castle nut for the front end of your Jet 250, it is a Metric, size 10 fine thread. I could not find a castle nut in this size, so I bought a regular nut and cut it myself. Actually, I bought two and cut them both. Also got some real deal pins, and they are MUCH MUCH stronger than the factory pins.
Old Dec 13, 2007 | 01:34 AM
outofline's Avatar
As I had said before Raceway sent several of us new jets for the 250, I can't recall the sizes but others on the Raceway area of this forum swapped theirs out also and can be more help. You may want to post there from now on as that is where the Jet owners typically hang!
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Whitelx1
Oct 2, 2015 10:55 PM
wrencher82
Sep 30, 2015 04:27 AM
r1pilot83
Sep 27, 2015 07:38 PM
