Giovanni 110 front and rear sprocket - regearing
Old Mar 30, 2008 | 03:37 PM
Sparkadelic's Avatar
Default Giovanni 110 front and rear sprocket - regearing
Wanting to change the final drive ratio on my boys 110 mini hummer. It has a 14 tooth front and a 37 tooth rear. I want more low end toque and willing to lose some top end obviously. This Gio gets a little hairy at the top end for my 7 year old.
I have seen 13 tooth fronts for the 110 chinese motors, but was thinking more like 12 or 11. What should I be looking at for a rear. And where?
Thanks a lot for the help,
Brad
Old Mar 30, 2008 | 06:37 PM
slydogsrus's Avatar
Take measurements of the front sprocket shaft and it's mounting holes in millimeters along with your rear and front sprocket tooth count currently installed. Also measure your chain to figure out if you have a 428 or 420 chain using the link below. Then PM (private message) me and maybe I can help you out................Slydog
http://www.gizmology.net/sprockets.htm
Old Apr 2, 2008 | 07:27 PM
jojo_tkc's Avatar
Sly, do you work at a sprocket manufacturer or something?
Old Apr 2, 2008 | 09:18 PM
slydogsrus's Avatar
No, just an auto mechanic with an electrical engineering degree trying to help if I can.....................Slydog
Old Apr 4, 2008 | 08:14 AM
jojo_tkc's Avatar
sweet
rcappie4
Jul 18, 2015 07:51 AM
Peter_
Jul 18, 2015 07:06 AM
tporath
Jul 11, 2015 12:31 PM
rcappie4
Jul 10, 2015 04:54 PM
cSchwartz
Jul 9, 2015 02:40 PM
