LT80 HELP!
Old Jun 27, 2008 | 11:25 PM
jmh139's Avatar
Default LT80 HELP!
I got the carb kit in, changed back to standard jets and it fired right up. Seems to run great now, we will take it for a ride this weekend.
I have a question about the gas shutoff valve. As I mentioned above, it is broken in the full flow position and I have another cut off added. I am curious why the gas would keep flowing with the valve on. Wouldn't the float in the carb stop the gas from filling the head?
Thanks again for all the help! Jay
Old Jun 27, 2008 | 11:44 PM
onebigzj's Avatar
Default LT80 HELP!
lots of pressure on the float . both of mine have the same problem
Old Jun 28, 2008 | 02:38 PM
LT80's Avatar
LT80 Expert
Default LT80 HELP!
Someone may have gutted it out. I did for my race LT's.
So what size jets were in it?
Old Jun 28, 2008 | 09:41 PM
NJDale's Avatar
Default LT80 HELP!
<div class="FTQUOTE"><begin quote>Originally posted by: onebigzj
while your at it change the air in the tires. it might have mold in it!!!!</end quote></div>
When 'changing the air' in my tires - I prefer to remove the valve core, let all the 'old bad air' out, give each of the a shot of 'lemon bathroom air freshener', reinstall the valve core, then fill to 3 or 4 psi with fresh clean air.
That way when I am out riding - if I smell 'lemons', I know that either I am getting a flat or I have run over someones 'lemon tree'.
I also have a part ownership of a 'diamond mine' located in NJ for sale.
Old Jul 9, 2008 | 02:19 AM
  #15
miker660r's Avatar
Default LT80 HELP!
Banshee petcocks work too.
Old Jul 20, 2008 | 03:50 PM
  #16
bigheadkolby's Avatar
Default LT80 HELP!
I sent you a pm
<div class="FTQUOTE"><begin quote>Originally posted by: jmh139
I just bought a 88 LT80 for my son, and one of the first things I did was change the pipe from a DG back to a stock pipe. I bought a new one from ebay, the old pipe is LOUD and my son was kinda scared of it.
After replacing the pipe, everything ran fine for several days of yard riding, until we drove it 100 miles away to ride. It would not crank (boy was he disappointed!). When we got back, I started checking and found that the new pipe and muffler was FULL of fuel. I mean a lot. I took it off, and changed plugs and tried to crank it (without a pipe). The carb is blowing fuel from the exhaust port.
I am thinking I need a carb rebuild kit. The guy who had it before me had rebuilt the engine better than stock and changed jets in the carb. My question is, should I be able to get a stock carb kit and put it back stock? Is this most likely my problem (or something else in the carb)?
Since he rebuilt the motor previously, is there something he may have done in there that requires the rejetted carb and exhaust, or will putting it back stock be OK?
Thanks for any help!</end quote></div>
Bob E.
Oct 1, 2019 09:08 AM
QuadRiders
Oct 22, 2015 04:13 PM
merryman
Sep 19, 2015 03:15 AM
Jaymc
Sep 11, 2015 07:45 AM
Bergmann
Aug 13, 2015 03:51 PM
