Replacing Clutch cable
hey outofline im having this problem adjusting the clutch cable for some reason it wont get in gear do you know if there is a special way its sopposed to be adjusted? I already adjusted the 2 nuts all the way and it still seems not to go in gear i measured the cables and they seem top be same length and all. is it supposed to be assembled a certain way or something????? Please help if you have any tips thanks
Here is where my Clutch cable is adjusted to. Yours should be pretty close!
If you go to far one direction it will not want to shift into 1st (when started) and when you start it it will want to start rolling. If you go to far the other dirrection it will slip as you accelorate in all gears!
well i took pics of mina as well when i took mine apart first and ive tried to adjust it to where it was before but no luck. Im wondering if you just adjust little by little and the try it cause it seems like when i adjusted right know like it wanted to goin gear but didnt and i can shift into R or 1st and and give it gas and it just idles or revs the engine. could it have been that something slipped off that clip and thats why it dont go in gear? Thanks
#15
yeah you know it will go into 1st and R only but i cant remember i think its always gone into 1st but not in R without pressing the clutch in. i think i just have to adjust and check adjust and check. I belive it needs to hit perfect for it to go in gear well see this week cause family was in town so didnt have time sat or sun
GregM
Mar 6, 2018 06:53 AM
