Help Vbike wont move
We have the 300 monster from Vbike (i think its a tao tao) it wont move. It feels like it clicks into gear when you shift it (manual) but it won't move. there were not horrible noises like we broke something it just wont move in any gear not even reverse. We are lost. Any suggestions? Maybe a clutch?? HELLLPP!
Is this atv new? Did it ever work? No matter what gear it's in with the motor OFF, Clutch out can it be easily pushed forward with no restriction from the motor? If so I would say it's got to be the shift fork or something inside the transmission and it's in Neutral and can not be shifted into any other gear! Is the indicator on the handle bar display showing Neutral? Sounds like it may be an ugly repair! Unless the clutch cable is way engaged all the time I can't seeing it being the Clutch. You can adjust the clutch cable but I don't think that’s going to do it!
Vbike wont move?
new or not give Tim a call at Vbike or send him an email. They are an impoter if you didnt buy it from there . But, Tim is very up on the mechanics of most all of his inventory. Tell him what its doing and how it acts. most likely he will give you some very good hints for what to look for
Elkaholic
09-06-2015 02:44 PM
