Polaris 50cc predator (2004) loss of power.
Old 01-14-2011, 06:22 PM
rom58's Avatar
Default Polaris 50cc predator (2004) loss of power.
Hey guys. Need a little help here. Got an 04 predator (50cc) that had a loss of power. Pulled the tranny cover and found that the belt looked good, but there was oil present and the belt was wet. Is this normal? If not, what would cause it? Also, need help figuring out how to get that kickstarter back in place. That spring is a pain. Any help would be great!
Thanks,
jon
Old 01-15-2011, 07:41 AM
LT80's Avatar
LT80 Expert
There shouldn't be oil in the belt area that's for sure. Maybe a main seal.
Sorry, can't help w/kickstarter. Most all I've seen stays on the clutch cover and wasn't a issue durring clutch maint.
Old 01-15-2011, 10:29 AM
rom58's Avatar
There is no oil in the motor (2 stroke). Odd huh? Baffled.
Old 01-15-2011, 12:23 PM
LT80's Avatar
LT80 Expert
I understand that.
I did neglect to mention that it could be the gearbox gasket.
Old 01-15-2011, 03:12 PM
rom58's Avatar
Is it possible that oil from the oil tank directly above has leaked in over time or through the vent tube? I pulled it all apart and don't see a clear leaking point. On a good note I was able to fix the clutch issues. It now has full power and breaks the rubber loose in our driveway. Just gotta find that leak.
bzdok1234
30
02-23-2016 01:55 PM
1966F100
07-14-2015 12:19 PM
Gtsordo
07-13-2015 10:38 PM
1966F100
07-12-2015 03:08 AM
steveo612
07-11-2015 08:35 AM
Quick Reply: Polaris 50cc predator (2004) loss of power.
