2001 Yamaha Breeze
Old Jul 23, 2011 | 09:44 PM
pjmia96's Avatar
Post 2001 Yamaha Breeze
How do you coldstart a Yamaha Breeze 125 that has sat for 4 years?
Old Jul 24, 2011 | 05:55 AM
Jaster94's Avatar
others will chime in but this is what i've done, i may learn some more tricks with this thread. But i would thoroughly check the wiring(depends on environment the quad was stored in), then i would change the oils, flush the fuel tank and install a new fuel filter, inspect/change fuel hoses, change spark plug, clean the carb/jets, inspect/clean or replace air filter, grease everything, wash it, install a new battery if applicable, then fire it up. watch for leaks for a few minutes. if all is well, put it in gear and ride.
Old Jul 24, 2011 | 07:24 AM
Scooter86's Avatar
Knows Old ATV Questions!
That is pretty much what I would do as well. fresh oil, fuel, spark plug, clean and oiled air filter, clean the carb and give her a go.
Old Jul 24, 2011 | 09:42 AM
pjmia96's Avatar
Post Oil
Should I Squirt any mystery oil down the cylinder?
Old Jul 24, 2011 | 01:38 PM
Jaster94's Avatar
i don't know much about the mystery oil, but i really don't see a problem with doing that. just turn the engine over quite a few revolutions by hand or by ripcord to work it in with the spark plug pulled out.. then you could probably fire it up.
i just don't know about that mystery oil stuff.
Old Jul 24, 2011 | 07:51 PM
Scooter86's Avatar
Meh, you could do the mystery oil if you like.It actually wouldn't hurt just to pull the cap off the spark plug and turn it over a bunch to get all those internals coated with oil again before the first go at trying to make it run.
Hunter100us
Oct 7, 2015 11:46 PM
ghost civic
Jul 30, 2015 04:09 PM
ghost civic
Jul 27, 2015 03:15 AM
ghost civic
Jul 15, 2015 10:48 PM
maxjung
Jul 14, 2015 03:10 AM
