Lt80 help needed.
Old Jan 19, 2012 | 03:04 PM
Backstep11's Avatar
Default Lt80 help needed.
New to forum but have been lurking a while. A lot of great info. Thanks! I have an 03 and an 05. The 03 is new to me and im having a hard time with it. It sat for a while so I bought a new battery. Rebuilt the carb and cleaned out tank and petcock. It was turning over but now the starter relay just clicks. I's not the relay because it works fine on the 05. Please any help I could get would be great!
Old Jan 19, 2012 | 06:10 PM
Backstep11's Avatar
Ok, found the reset switch under rear fender. Still will not start though. Any ideas what to do next?
Old Jan 19, 2012 | 09:27 PM
LT80's Avatar
LT80 Expert
Got spark?
Plug wet? If not, hand choke it (fingers in front of carb) and see what happens.
Plug wet? if so, it's flooded. WOT till it starts and cleans out.
Old Jan 24, 2012 | 11:49 AM
Backstep11's Avatar
Ok got it going. Won't stay running for too long without the choke on. I tried playing with the adjustment screw but cannot seem to get it right. Also there seems to be some oil coming through the exhaust. Any ideas? Any help would be appreciated!
Old Jan 24, 2012 | 11:57 AM
Backstep11's Avatar
I checked other posting and found the oil might have something to do with the needle. I rebuilt the carb. The needle hangs off the float. Was there supposed to be some type of gasket below the needle or is the rubber tip on it ok. I didn't see one in the rebuild kit I bought. Anyone????
Old Jan 24, 2012 | 12:16 PM
Backstep11's Avatar
After reading through the other posts, what is meant by the seat that goes along with the needle? S orry if it's a dumb question but I'm new to all this!
Old Jan 24, 2012 | 11:26 PM
LT80's Avatar
LT80 Expert
The seat is where the needle contacts. There is no gasket.
All is normal there.
If you can blow thru it, it's usually fine.
I blow thru it and work the float to see if it's working properly.
Old Jan 25, 2012 | 11:26 AM
Backstep11's Avatar
Anyone have any ideas about the oil coming from the exhaust????
Old Jan 25, 2012 | 11:58 AM
LT80's Avatar
LT80 Expert
Sorry...
That's normal.
Old Jan 26, 2012 | 01:09 PM
Backstep11's Avatar
Ok thanks. I cleaned the carb again and I'm looking to put an inline fuel shutoff on the fuel line. I think my petcock is failing. Autozone doesn't have them so I guess ill keep looking. This forum has really helped!
