LT80 Stalls out past half throttle
Old May 16, 2012 | 05:23 PM
huenix's Avatar
Default LT80 Stalls out past half throttle
Background: I rebuilt and cleaned the carb with stock jets because it would not run without the choke on, and the quad came with a rebuild kit. It fired right up after putting it all back together. I can ride it (mostly) around the yard but when I get near half throttle, it bogs down. If I hold the throttle in, it dies, if I let it go, it goes back to idle just fine.
I screwed around a bit with the needle but couldn't get it to really go.
Spark is good, compression seems great but I don't have a gauge. I pulled the air filter and the previous owner apparently didn't soak the filter but there wasn't much in the intake that would indicate it was leaking. I was going to reassemble with the air filter soaked as it should be but ran out of time tonight.
Suggestions?
Old May 17, 2012 | 08:19 AM
LT80's Avatar
LT80 Expert
You may have a bad carb.
I think you need to do a comp test to eliminate that aspect.
Old May 17, 2012 | 08:58 AM
huenix's Avatar
I think I do too but I don't have a gauge. I am combing my local area to see if anyone has one I can borrow.
Old May 17, 2012 | 11:26 AM
LT80's Avatar
LT80 Expert
If not, Sears has them. I think I paid 15-20 bucks.
Old Jun 2, 2012 | 06:44 PM
huenix's Avatar
Took me three weeks to get back to this, but I pulled the carb apart and soaked it in cleaner, reassembled, runs like a maniac. I can't honestly believe that a 80cc engine thats 12 years old will haul my butt down the road like it does.
Now the idle speed is too high but thats an easy fix.
scram5050
Aug 30, 2024 01:39 PM
skinnyr6
Aug 25, 2023 02:18 AM
Polarisman1123
Sep 13, 2015 10:06 AM
DanP24
1) Engine problems..
Aug 13, 2015 09:14 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
