LT80 - thanks:-) and locked solid SOLVED
Old Jun 18, 2012 | 06:10 PM
sengle's Avatar
Default LT80 - thanks:-) and locked solid SOLVED
Hi all,
A big thanks to you all as I researched this site so that I could decide on what quad to buy. I settled on a LT80 and used this site so that I knew what to look for when buying.
Anyway I got a 1997 and it only had 70psi compression, so I put in a new top end and shaved the head. Also serviced the clutches (removed 2 rollers), cut the footpegs (makes life a lot easier for future clutch work), bypassed the oil pump, got a pull starter for it, installed fuel filter and new On/Off tap, Boyesen reeds, added 2.5" spacers all round.
It now goes great so thank you all - especially 'LT80' (Jack I think?) as the information here was really useful.
Just as a piece of useful information for you all - after I had put it all back together it would not turn over and was locked solid.
I thought that I had stuffed up the clutches, but in the end it turned out to be a bolt that was too long on the pullstart cover at the '9 oclock' position. I had replaced the bolts with socket (hex) screws and I accidentally used one that was too long (15mm instead of 12mm) and that was jamming the front fixed drive face. Simple
Just a quick question - should I block off the vaccuum port from the carb as the new fuel on/off tap does not use vaccuum.
Cheers from New Zealand.
Steve.
Old Jun 18, 2012 | 08:42 PM
LT80's Avatar
LT80 Expert
Welcome to the forums.
Yes, you need to block off the vaccum port.
I have a motor in NZ. Seen a fast one down that way?
I have a cpl motors in Australia but I heard they got stole....BAHAHAHAHAHAHA LMAO!
I'm told that's a NZ joke.
Your very welcome. As you seen, there are alot of good mates here to help.
Have fun!
Old Jun 18, 2012 | 08:50 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
better get a second opinion on any advice lt80 gives you.... he's been known to not take his meds for weeks at a time and start giving out faulty info
lt80
95wolv
Sep 27, 2024 12:00 PM
exmotocrosser
Sep 13, 2019 06:12 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
merryman
Sep 19, 2015 03:15 AM
