Lt80 sticking front brake only one side
Old Aug 6, 2012 | 12:10 PM
Gsi-mark's Avatar
Default Lt80 sticking front brake only one side
Got this prob when changing front pads the shoes stick but I can move I back manual but sticks on with the lever
Old Aug 6, 2012 | 12:42 PM
DAMONSQUAD's Avatar
i'm going to assume you lubed both cables and made sure they were good to go first.
second make sure there is the return spring on the lever where the cable attaches to the backing plate, and lastly, pull the lever that spreads the pads out when you pull the brake, out of the backing plate and clean it up and lube it, they get sticky in that bore sometimes
Old Aug 6, 2012 | 04:10 PM
LT80's Avatar
LT80 Expert
"pull the lever that spreads the pads out when you pull the brake, out of the backing plate and clean it up and lube it, they get sticky in that bore sometimes"
What he said.
Old Aug 6, 2012 | 05:02 PM
Gsi-mark's Avatar
Its the lever back of drum it works fine with the hub off wen u put it back on pull the brake it sticks solid take it off and it works fine
toonces
Oct 16, 2019 12:11 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
jettman
Jul 6, 2015 12:16 PM
Jkfx400P
Jul 6, 2015 10:04 AM
Mphillips
Jul 2, 2015 07:20 PM
