2000 econ dxl90-no start
Old Oct 19, 2012 | 03:11 PM
12311954's Avatar
Default 2000 econ dxl90-no start
I have a 2000 econ dxl90 that i can't get started. I turns over great but there is no spark at the plug. fuel is good, oil is good. any suggestions?
Old Oct 20, 2012 | 12:03 AM
LynnEdwards's Avatar
Electrical Expert
Do you mean "eton" dxl90? How many pins on your CDI, and what are the colors (use wiring harness side colors of any inline connectors - if that applies).
Old Oct 20, 2012 | 09:51 AM
12311954's Avatar
Sorry, meant to type eton. Wire colors at cdi are as follows: blue/yellow, black/red, black, black/white, brown, white/blue
Old Oct 21, 2012 | 09:20 PM
Electrical Expert
Wow. Your colors match the wiring diagram I have. Such luck... It usually aint so...
I have to say from the outset that I've never even seen an eton quad of any kind. I'm working off published eton data, and a good general knowledge of electronics
Unplug your CDI. Turn the ignition switch off.Then use a meter to measure the following:
1) Set your meter to measure resistance (ohms) on the 2K ohm scale (2000 ohms). Measure the resistance of the blu/yel wire to the black wire. What do you measure?
2) Using the same setup, measure the resistance from the blk/red wire to the black wire. What do you measure?
3) Turn on the ignition switch, and set all kill switches to the run position. Set your meter to measure ohms on the lowest ohms scale you have. Hopefully this is something like 20 ohms, or 2 ohms, full scale. Measure the resistance of the blk/wht wire to the blk wire. What do you measure?
4) Same setup, measure the resistance of the wht/blu wire to the black wire. What do you measure?
5) Switch your meter over to measure DC volts n the 20 volts DC scale. Turn on the ignition switch and measure the DC voltage on the brn wire to the blk wire. What do you measure?
This is just a start. These measurements will help split apart those things that are working versus those that are not. From there we can dig in deeper...
green giant
Jul 13, 2017 12:07 PM
wildbill59
Jun 20, 2015 02:26 PM
wbfjim
Jun 8, 2015 06:20 PM
1000gade
May 27, 2015 12:37 PM
