Piston and boring question?
Old Feb 5, 2013 | 04:51 PM
Suzukilt80crasher's Avatar
Default Piston and boring question?
Well here the thing I have an lt80 and need new piston I don't want to get stock 50mm I want 52mm or 51.50mm will I have to bore it?
Old Feb 5, 2013 | 05:30 PM
LT80's Avatar
LT80 Expert
1) you only want to go as big as you need to ie: if your at stock bore (50mm), you'll go to 50.5mm
2) yes, the cylinder will need bored and honed to the correct size piston.
If you don't have a local shop that does this work, I can do it for you.
Old Feb 5, 2013 | 06:28 PM
Why only .5 bigger I seen guys going up to 4mm bigger and how much do you price
Old Feb 5, 2013 | 09:06 PM
Hey lt80 do I need a sleeve to oh and if say I just get a stock bore which is 50.00 is it still better than the suzuki lt80 stock piston or what please answer and thx.
Old Feb 6, 2013 | 12:07 AM
LT80's Avatar
LT80 Expert
Because there is a very minimal increase in hp in boring 80cc motors.
Porting is where you increase rpm's/hp.
No, you don't need a sleeve. The LT80 cylinder can be bored out to 52mm.
You're talking about the big bore cylinders (+4). Not the best choice for durability and also, LA Sleve isn't going to make any more and they only have 54.25mm and 54.5mm pistons available.
Old Feb 6, 2013 | 07:39 AM
Why don't I go higher then like 51.50mm instead of the .5mm increase thx again.
Old Feb 6, 2013 | 08:42 AM
LT80's Avatar
LT80 Expert
To go more than needed is a waste of a bore. The sooner you bore them to the max (52mm) the sooner you buy another cylinder.
Old Feb 6, 2013 | 10:58 AM
Same thing I tried to tell people for years! Some kept thinking they would tell a great difference in power if you bored a cylinder all the way out. All you're doing is just wasting a good cylinder. OPT
atvcollector
Sep 8, 2015 05:11 PM
Jason Richards
Sep 4, 2015 06:17 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
