Lt80 drive
Old Mar 3, 2013 | 06:33 PM
  #21
Suzukilt80crasher's Avatar
Originally Posted by Suzukilt80crasher
I ordered a moose racing 13t sprocket
I was going to order it then I seen the more speed sprocket set on ebay and I might get that but I was wondering if I keep the stock 22t rear and chain I have on now and get a 13t front sprocket will it work?
Old Mar 3, 2013 | 06:41 PM
  #22
LT80's Avatar
LT80 Expert
I'm going to -->presume<-- that you ordered a sprocket for a 99 model which would be a 520 pitch sprocket. This matches your 22 tooth rear sprocket.
You will need to buy a chain and cut it to length. Then if it's loose, you'll need to make or buy a chain tensioner.
A 13 will make it take off slower and top end will take a while but it will be faster.
Old Mar 3, 2013 | 08:34 PM
  #23
Should I just get the more speed gearing kit on ebay in it you get a 520 chain a stock rear sprocket and a 13t front sprocket
Old Mar 3, 2013 | 09:42 PM
  #24
LT80's Avatar
LT80 Expert
Prolly be easier for you.
Old Mar 4, 2013 | 10:21 AM
  #25
LT80's Avatar
LT80 Expert
I should add:: a 520 13 tooth sprocket is much bigger than a 428 13 tooth.
The ads you mention is prolly for the 428 size which may give you the desired 5mph faster.
Old Mar 4, 2013 | 04:04 PM
  #26
Where can you get that size of sprocket
Old Mar 4, 2013 | 08:41 PM
  #27
Jaster94's Avatar
look to the sponsors of the forum and they can help you out. contact them via private message to order. they're knowledgeable and will help you out ASAP. go to the atv community page and look for the sponsors. then contact them, then buy from them, then install your new parts, then go have fun.
Old Mar 4, 2013 | 08:46 PM
  #28
Do you know any of the sprocket sponsors?
Old Mar 4, 2013 | 09:02 PM
  #29
Brian Adwell's Avatar
I need counseling after all this !! LMAO!!
Old Mar 4, 2013 | 09:16 PM
  #30
Lol I'm so clueless I can't find a sponsor either someone just tell me what to buy I'm not cheap so whatever shoot me something thx
