LT80 w/PVL top-end stutter!
Old Aug 5, 2013 | 08:12 AM
  #21
LT80's Avatar
LT80 Expert
1/2 second. Let's change a motor.....LMAO
I'd think that would be tremendous for a young lad like him.
1/2 second could be many things. You could:: fine tune the motor, fine tune the clutchs, work on machine set-up including lowering the center of gravity.
That should keep you busy.
Old Aug 7, 2013 | 06:07 PM
  #22
Brian Adwell's Avatar
What would cause the stage2 motor to bog alittle on take-off then after about 20ft it hits hard?It will bog after a sharp turn or coming out of the barrels.How would you go by lowering the center of gravity,that would help tremendously? Thanks for your help Jack
Old Aug 7, 2013 | 10:03 PM
  #23
LT80's Avatar
LT80 Expert
Been into the clutchs lately?
That's where I'd start.
I'd look for some 16.5 tall tires. Most use what's called "snow hogs".
Old Aug 8, 2013 | 09:26 PM
  #24
I have 16x6.5-8 snow hogs on it already.I did go in and check clutches and re-scuffed belt grab areas last night,had a little dust so I just cleaned with carb cleaner and put back together also went ahead and put in 3 new rollers.
Old Aug 8, 2013 | 09:34 PM
  #25
Jack,did you get my email?
Old Aug 8, 2013 | 09:44 PM
  #26
LT80's Avatar
LT80 Expert
Ya, we're all good.
16.5's on the front too?
What's the plug look like?
Old Aug 9, 2013 | 07:16 PM
  #27
I had re-drilled some 10in for the fronts,on my lunch break I took Bryson's rears off his and I put them on Rivers so now it has 16" snow hogs front and back.I pulled the spark plug last night and it was black and wet.Should I go down 1 size on the main jet? I did lower the needle and I think it helped throttle response.
Old Aug 14, 2013 | 06:30 PM
  #28
Would you have a way to troubleshoot and find out what the problem is if I where to just send the motor to you? This thing missing on top is about to drive me and the boys absolutely NUTS!! Is there a way that it could be sucking the bowl empty?Is there a way to test magneto/pickup of the pvl?I had the coil tested and it checked out to be good.
Old Aug 17, 2013 | 05:45 PM
  #29
Any suggestions on what to try next? Is their a way to check firing at a high rpm? What size pilot and main jet size should I put in the stock carb to be sort of close?
Old Aug 17, 2013 | 09:53 PM
  #30
LT80's Avatar
LT80 Expert
Did you not get my email? I asked questions.
See if you can find it, figure out the answers and let me know.
We'll go from there.
I prefer to fix this in emails.
