LT80 w/PVL top-end stutter!
#15
Jack,yesterday i just swapped over all of the fuel side of River's cause I knew it ran well and when I started it it did'nt want to go like taking off in high gear so I suspected a clutch prob. then so I just shut it down. This morning I got into the clutches and its all jacked up! Rollers are melted and flat and there was alot (about 4 table spoons of what looked to be aluminum powder everwhere)? Im gonna clean everthing up and replace the 3 rollers thats in it,i think i have 3 new ones.What I really need is a national motor.Lol
#16
#17
The clutches worked flawlessly until yesterday after I put the other carb from your motor on it.I was checking to see if the carb.fixed the problem then this happened.I took clutches apart after work this afternoon and I found that the inside sheave has came apart and was rubbing the inside part of the case housing.This part is the first part that would go on the driven shaft if you was putting everything back together,I wonder if its possible to weld the inside sheave back on?Don't really know what to do?Any advise?
#18
#20
