&$%^ Carburetor Screw on LT80! HELP!
Old Aug 10, 2013 | 05:51 PM
Sunsetnewbie's Avatar
Default &$%^ Carburetor Screw on LT80! HELP!
OK - I m new to four wheelers, but have worked on "things" for years...how in the heck do you get to, and tighten the left side carburetor mounting bolt/screw???
It is 8mm or so it appears, but I cannot find a wrench that can access it.
At least the right hand side you can tighten with a screw driver from the front of the engine.
I thought I had it tightened, and it has worked loose again, causing a massive vacuum leak and poor performance.
My 13 year old son is going nuts because Dad cannot fix it.
ALL HELP IS APPRECIATED!!
Old Aug 10, 2013 | 08:48 PM
LT80's Avatar
LT80 Expert
Welcome to the forums.
I use a 8mm Snap-On wrench. It's thin enough to work.
I imagine that you can grind a craftsman down to fit.
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Beeline08
Nov 11, 2016 04:00 PM
Oct 10, 2015 10:20 AM
Jackg17
Sep 26, 2015 09:30 PM
