05 Polaris Predator problems
Old Aug 23, 2013 | 04:13 PM
LakinsDaddy's Avatar
its running great now. im guessing it was just the fact it hadn't been run in a while. got the carb adjusted right and it runs good without dying. I don't have access to a comp gauge either. the only problem it has right now is the voltage jumps around from 13 to 16v
Old Aug 23, 2013 | 06:16 PM
Replace that regulator..If you install a new battery the higher voltage back to the battery will just overheat it and short out cells.
Old Aug 24, 2013 | 02:21 PM
ok. i will get a new regulator before I buy a battery then. will the30 dollar batteries on ebay work fine or should I buy one from advance auto?
Old Aug 24, 2013 | 02:45 PM
A little cheapo YTX(BB)5LBS from Wally World or any where is fine for these little atvs,unless you just want to spend more on a better battery.
Old Aug 25, 2013 | 01:50 AM
  #15
ok good. ebay has one for 27 and my local advance auto has one for 29
cbcole02
Sep 7, 2015 06:16 AM
Berjr
Jun 15, 2015 04:41 PM
Predator_500
Jun 13, 2015 03:01 PM
TJM
Jun 11, 2015 01:28 PM
Falcon150
May 25, 2015 05:36 AM
