LT80 KFX80 carb issues
Old Jan 21, 2014 | 05:45 PM
kaw753's Avatar
Default LT80 KFX80 carb issues
I bought a 2003 KFX80 a few months ago. The **** for the choke was missing. I recently purchased a 1989 LT80 for parts. Both have Mikuni carbs that look identical, but I found that the choke (plunger) assemblies will not interchange (one is smaller than the other where it screws in the carb). Is this due to the year differences? Also, I need the fitting that goes in the side of the carb for the oil line; I'm assuming this is not available by itself, and I will need to find a used or junk carb to get this fitting? Thanks for any info.
Old Jan 21, 2014 | 06:55 PM
Lt Granddad's Avatar
Other than pull **** does the carb seem to serve its purpose making the bike run. If it does u could use some hand grip wire to twist in the groove on choke stem and leave a loop to pull with finger or attach wire to something the size of a dime to pull and use to push down the choke stem. Or look at stem size of both carbs pull **** off and put on other with epoxy or super glue so it doesn't fall off that is the cheapest fixes
Jmuddin284
Jan 19, 2026 07:16 AM
Sjrpp
May 2, 2023 03:59 PM
tweeder
Jul 5, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
Mikea1978
Jul 4, 2015 12:37 PM
