04 eton 90 viper backfire n bogs
Old 10-20-2015, 06:49 AM
LT80's Avatar
LT80 Expert
Metal or fibre.
You'll find out when you check them.
Old 10-20-2015, 02:16 PM
Joequad5150's Avatar
reeds are good. I have a new plug coming in the mail .. But It is still a mystery . If its electrical It should be at idol too ? No ? Its an under load condition when it breaks up ...
Old 10-20-2015, 02:27 PM
LT80's Avatar
LT80 Expert
"If its electrical It should be at idol too"
Not allways.
You can try pulling the flywheel off to clean it and the stator. I've seen them yucked up and cause trouble.
I'd find the cdi and stator ohm specs and test them.
Old 11-01-2015, 04:26 PM
Just ordered a new coil ...Must be an ignition problem.Not much left it could be ..
  #15
Old 11-03-2015, 06:55 AM
LT80's Avatar
LT80 Expert
Did you check the ohms of the stator and coil?
  #16
Old 11-06-2015, 02:15 PM
Replaced the coil.. quad works like new again..
  #17
Old 11-10-2015, 01:53 PM
ok the coil did work out . Think the CDI module is not working right . Replacing the coil worked . But the quad is breaking up again . Full throttle it runs great but starts to break up again and bogs out . Thinking the CDI is also bad. anyone have one go bad ?
  #18
Old 11-11-2015, 08:28 AM
LT80's Avatar
LT80 Expert
I know you have a new top end but what was the comp reading?
  #19
Old 12-18-2015, 04:17 PM
Funny how things work out.. I sold the eton 90 . Got what I wanted but the good part was I did get it running great before selling . Verdict ??? Dirt in the fuel tank was clogging the fuel line before the on off valve. So when it was running out of fuel ( hien sight ) the reserve position was clogged . good times !
freeman34
01-08-2016 11:46 AM
firsttimerider
Technical and How-To Articles
09-07-2015 11:43 AM
momma's bike
08-06-2015 09:49 AM
toonces
07-24-2015 09:03 AM
Quick Reply: 04 eton 90 viper backfire n bogs
