Eton 90 Dxl starting issue
Old 12-15-2015, 07:36 AM
Mcobb1's Avatar
im thinking its got to be something in the slide. It didnt do it before and i removed the trottle cable from slide and replaced with new one so it may be something there
  #22
Old 12-15-2015, 09:46 AM
LT80's Avatar
LT80 Expert
Once I forgot the lil washer thing that holds the needle down.
Sounds like you may have also.
  #23
Old 12-15-2015, 09:57 AM
Mcobb1's Avatar
the little metal clip? that goes in the grooves of the needle?
  #24
Old 12-15-2015, 01:14 PM
  #25
Old 12-15-2015, 01:17 PM
Mcobb1's Avatar
i replaced the carb- granted it was used. I used the best components from the two carbs i had and put on new one.
  #26
Old 12-15-2015, 01:20 PM
Man I wouldn't fight it!! Just get a new carb for 20 bucks.Carburetor E Ton Eton 2 Stroke RXL90 RXL 90cc ATV Carb Hand Choke H CA59 | eBay Or here's one for a Viper and they throw in a filter. http://www.ebay.com/itm/Carburetor-W...RV4AHW&vxp=mtr
  #27
Old 12-15-2015, 01:23 PM
Mcobb1's Avatar
Oh believe me i would and probably will. But i think its user error on my part on the slide. I had a hell of a time taking throttle cable off and when i put it back on i may have jammed the slide somehow/ some way. At least that's my thought. i'm going to look at it later and see. I just don't have enough time to get it in before Christmas so my son can drive it Christmas morning.
I just dont want him to get on it and start it up and the thing take off like a bat out of hell screaming thru the yard. lol. EVen just idling in my garage it wants to move forward.
  #28
Old 12-15-2015, 05:11 PM
LT80's Avatar
LT80 Expert
If you click on OPT's carb link, #30 is what I'm talking about. Without it, the needle floats.
  #29
Old 12-16-2015, 05:18 PM
Mcobb1's Avatar
Okay. Disassembled carb and put back together. Fixed float. It was hanging low ( when flipped upside down) so I adjust the tab to where it is parrellel (the float) with the carb lip. I read this or watched a video. Now it wont start- it isn't pulling any air thru the intake. What to do now
  #30
Old 12-16-2015, 05:59 PM
If it has decent compression(100 psi or so) and spark, just order a new carb for 20 bucks,5 bucks for expedited shipping and you can have it in a couple days. This will replace the Frankenstein carb that you made out of two carbs and can be done before Christmas.Carburetor E Ton Eton 2 Stroke RXL90 RXL 90cc ATV Carb Hand Choke H CA59 | eBay
Quick Reply: Eton 90 Dxl starting issue
