LT80 startfailure
Old Feb 27, 2017 | 12:00 PM
  #21
Anders Berggren's Avatar
No I haven't got a round to buy a comp tester. You think I should now that it fires up?
Old Feb 27, 2017 | 12:43 PM
  #22
DirtDevil101's Avatar
Yes...low compression engines will fire up and even run under part throttle, but under full load the expansion from heat creates an environment where combustion can no longer take place...and they die. I thought that was a condition you were experiencing?
Old Feb 27, 2017 | 02:11 PM
  #23
Aaah I see. I haven't got to try full throttle. Just started it up in the garage tonight. I'll get my self a tester and see. What value should it have if it's "good"?
Old Feb 27, 2017 | 04:11 PM
  #24
LT80 may over-rule me here but I'd say:
100psi = livable
110 - 120psi = good
120+ = Ye Ha!
Mine pulled a 130 on a stock motor when I picked it up for reference...
Old Feb 28, 2017 | 07:54 AM
  #25
LT80's Avatar
LT80 Expert
90 minimum.
Borrow a gauge from autozone/etc.
Old Mar 1, 2017 | 04:04 AM
  #26
Did the compression test this morning. 150 psi should be ok, right?
Old Mar 1, 2017 | 09:04 AM
  #27
LT80's Avatar
LT80 Expert
hehe..It's fine. I didn't expect that much.
Old Mar 1, 2017 | 09:47 AM
  #28
It seems to run just fine now. The only issue I have left is that I have adjusted the throttlestop on the handlebar so they won't drive so fast and doesn't run clean at first. But when they have driven 50-100 meters you really hear that twostroke-sound. Shall I lower the needle some?
Old Mar 1, 2017 | 11:02 AM
  #29
Do you know how to read a spark plug?
Old Mar 1, 2017 | 11:42 AM
  #30
Can't say I do. Enlighten me?
