Suzuki LT80 using too much oil???
#25
Cleaned and replaced carb on other bike and starts first push of the button now. One small problem though, it’s leaking petrol from the carburettor. I’ve looked around online and see that it could be the float is stuck on?? I’ve also seen someone that has shot air up the fuel pipe to release the float? Would you recommend this to work? Thanks
#26
No. The float needle seems to get sticky. Ethanol has been a giant problem. I recommend a simple on/off valve close to the carb. Then you shut it off and let it run till dry. When you turn the fuel on it washes the needle off. This has helped a lot.
