Coleman AT125UT oil leak after replacing cylinder gasket
Old Nov 5, 2024 | 08:44 PM
BourgeoisUntapped's Avatar
Default Coleman AT125UT oil leak after replacing cylinder gasket
Hi, my issue is a simple one. I've replaced the gasket on the cylinder head and after reinstalling the cylinder everything seems to work except I'm leaking oil now from the bottom of the cylinder. I did use the torque wrench to crank it to spec but I feel I may have missed putting on the little sleeves that go over the long bolts, best I can explain this. Is there anything that someone can tell me that would affect the oil leaking out like that I don't know?
Old Nov 6, 2024 | 02:47 AM
If "the little sleeves that go over the long bolts" are the steel dowels, they are to ensure the cylinder is in the correct relationship with the crankcase, without them the cylinder can be off centre. If they are rubber tubes, that would be for sealing an oilway. Either way, best to remove cylinder again and fit a new cylinder base gasket, ensuring ALL of the old gasket material is cleaned off first, then fit those missing sleeves.
Old Nov 7, 2024 | 08:48 PM
Default Thanks
I appreciate that bit of info because I was wrong about those too. They are metal. So turns out my issues wash a washer I didn't see on there and it probably fell in the oil pan when I removed the cylinder head the first time problem solved. Thanks again
HarryJ
1) Engine problems..
Feb 26, 2024 02:25 AM
wadem
Jul 15, 2018 05:50 PM
alex2015
Apr 4, 2014 10:23 AM
nuyoricanpapi163
Sep 19, 2007 06:41 PM
power7
Jul 17, 2000 11:08 PM
