LT80 mods...jetting?
Old May 10, 2003 | 12:14 PM
HELIX's Avatar
Default LT80 mods...jetting?
I did a light trail port on our LT80,took about .005 off the head. Can anyone with past experiance recomend a main jet size? The bike is 1997,using stock exhaust,stock carb,etc. I bored it .020 over for a rebuild(had a lot of use in past 6 yrs),and used a wiesco piston(not my first choice but available quick).
It surprised me to see 150 lb compression after the engine was back together? Thanks in advance for any replies. ...Oh,my 8 yr old will be doing some 300 ft drags,any rec. sprockets with 19'' tires?
Old May 10, 2003 | 02:38 PM
LT80's Avatar
LT80 Expert
You can take .025 more off the head, but 150 is fine.Maybe a 2nd base gasket and more off the head.
Removing 2 front clutch rollers is a good thing. it will holeshot better.
You'll prolly need a 12 and 13 for a front sprocket.
Thats about all I can recommend for a stock motor. If you tell me exactly what you did porting wise (openings from TDC in degree's) I can advise further. [img]i/expressions/face-icon-small-smile.gif[/img]
Old May 10, 2003 | 03:50 PM
HELIX's Avatar
Thanks for the reply LT80. I never did put a degree wheel or indicator on it,I was just cleaning it up because it was off anyway. I raised the exhaust port 1 mm, and widened it a bit,cleaned up the transfers a bit. Thew compression seemed high to me for all that was taken off,I thought maybe from the weisco piston and aftermarket gasgets were not accurate. What jet do you think i should run????
PS I drilled a little out of each roller,they total 54g. (9g each) Thanks for your help,I made some jugements on this thing from reading your posts.
Old May 12, 2003 | 09:11 AM
LT80's Avatar
LT80 Expert
jets stock are: 92.5/17.5
I guess that I'd try a 90 or 87.5 main jet and pay close attention to the plug.Whats the plug look like now? (light/dark?)
Old May 12, 2003 | 05:45 PM
HELIX's Avatar
I'll stick a 90 in it and keep an eye on the plug,Thanks. I was wondering how sensitive they are to a little porting and compression,plus the fact that it now runs premix. How high have you gone on these things(compression ratio )on pump gas?
Bob E.
Oct 1, 2019 09:08 AM
QuadRiders
Oct 22, 2015 04:13 PM
merryman
Sep 19, 2015 03:15 AM
Jaymc
Sep 11, 2015 07:45 AM
Bergmann
Aug 13, 2015 03:51 PM
