connondale speed vs. predator
Old Jan 1, 2005 | 01:08 PM
  #31
Ernie660R's Avatar
Default connondale speed vs. predator
Originally posted by: WISTECH
Originally posted by: Ernie660R
Well lets say it is not cheap from going to 740cc Raptor engine, changing exhaust, carbs, air filters, piston, sleeve, boring cases, port and polish cylinder head, 2mm over valves (five of them) etc, etc.........
Those old school quads sure eat up the cash.
OLD SCHOOL!!! Hmmmmm
If I would have tried an electrical fuel injection it would have doubled in price....
Old Jan 1, 2005 | 03:15 PM
  #32
Sandgod's Avatar
Stage 8 update
Balance crank, Z400 bearing
Motor mount update
Stator update
Some will say aluminum oil pump gears and impellar, but it's not necessary
Or you can send your motor to a number of shops and they will do all the repairs.
Cord at ATK has done over 150 motors and alot of them w/ new 450 kits
Yours is an 03 so it will have some of these already done..
Old Jan 29, 2005 | 10:27 AM
  #33
2phast4u's Avatar
how much does all of that usally cost? i found a 02 cannible cheap but if im gonna havfta spend another 4k on it then nvm
Old Jan 29, 2005 | 02:41 PM
  #34
Sandgod's Avatar
About 2300 w/ Z400 big end rod bearing and the whole shubang. Wisetech can hook you up alot cheaper and he knows what he is doing... He founded the Z400 bearing trick..
Old Jan 29, 2005 | 05:36 PM
  #35
WISTECH's Avatar
If money is tight and you just want the major updates you get away with under $200 for the stud updates,z400 bearing,if you do all the work yourself. If you want ported heads, big bore stroker kits and the dozens of little trick updates cost goes up into the thousands,just like any other quad.
Pehter
Oct 3, 2024 11:00 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
ReconBayou
Sep 23, 2015 02:41 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
Elkaholic
Sep 6, 2015 02:44 PM
