Cannibal vs ds 650?
I recently bought a 03’ cannondale cannibal with ac nerf bars, ac front bumper, hmf full exhaust system, and stock mapping [img]i/expressions/face-icon-small-smile.gif[/img]. I was wondering what everyone thought if it was to drag against a ds650 with an alba pipe, what would the outcome be??? I’m thinking that the ds650 is going to smoke the cannondale, but I could be wrong. If that is the case and the ds would win, what upgrades could I do that would make the cannondale win?? Also I want a map that will give me the best power output (top end or acceleration) does anyone have any suggestions? thanks
You want to run a Moto/speed map. It is a blended map from two machines. You need a D&M kit to change maps and flowrate (mainjet), offset (Idle circuit), TS setting how hard you want the particular map to hit.. A Dale when set up properly will still run or outrun todays 450's let alone a DS..
It seems to have the most effect on a stock quad. The rev limiter is set at 11,800. its a fun map to try but al the power is at 10,000 and above. Id stick with a moto/speed blend or a blaze/ speed if you get arm pump with a more agressive map. There tons of maps out there and you can build your own if want to try. you can download them from other owners or get factory and custom ones off the Cannondale web sites.
Cannondaleriders.com Cannondaler.com they are free just like all the owners and service manuals. Download and enjoy
