Cannibal gearing
Old Apr 16, 2002 | 01:58 PM
  #21
trout's Avatar
someone stated that they can do most turns in 3rd and only 90 degree turns in 2nd, that is what I have found as well, one question, do you ever get into 4th gear on the MX track? I can seem to ever get there, I was wondering if spending a day in gears 1-3 most of the time is bad for the engine, high revs and all. I havent had a problem yet but just wondering.
Old Apr 16, 2002 | 02:05 PM
  #22
ltracerx's Avatar
Although I don't own a C-Dale, I spend all day riding in 2nd/3rd gear and I don't have any problems, unless thats what would cause my lower rod bearing to go out[img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 16, 2002 | 03:29 PM
  #23
Cannitor's Avatar
according to sidewinder the ratio of counter sprocket to sprocket is 1 to 3
1 tooth on the counter sprocket is equal to 3 on the sprocket
Old Apr 16, 2002 | 04:56 PM
  #24
1986atc250r's Avatar
Here's a Cannondale specific gearing calculator:
http://home.earthlink.net/~gellett/cdale.htm
Equivalence of rear sprocket teeth to front is a ratio - it's not just a flat three teeth to one or two teeth to one, it depends on their respective sizes.
Old Apr 16, 2002 | 04:58 PM
  #25
briansgi's Avatar
Cannitor, I posted earlier one tooth on the drive sprocket is equal to 3 on the rear, thanks for confirming!! I had a few doubters![img]i/expressions/face-icon-small-happy.gif[/img]
Old Apr 17, 2002 | 07:41 PM
  #26
[edit] the post I responded to was deleted...
lonerider856
Oct 13, 2023 03:45 PM
Honski250r
Sep 26, 2015 09:40 PM
patrick.oc123
Sep 15, 2015 02:45 PM
bigbear350quad
Sep 11, 2015 12:40 PM
awer1968
Sep 8, 2015 11:02 AM
