Trans. oil check bolt replacement...
Old Apr 26, 2002 | 03:25 PM
YoDaddy's Avatar
I failed to tighten my trans. oil check bolt enough and it fell out during my last practice (luckily at the end of it) but I didn't notice it until I unloaded my quad from the truck the next day. I haven't ridden it since Wed. (which is when the practice was) since it obviously won't hold any oil w/o that bolt. I didn't tighten the bolt enough because I was scared it was goin to break off in the motor. It stayed there for a race, lots of practice on the track, and lots of riding around my house but than Wednesday, it fell out [img]i/expressions/face-icon-small-sad.gif[/img]. Is there any kind of plug that I can stick in there and pop it out when I need to check the level. I would like a plug a lot better than a bolt so that I don't risk the chance of breakin the bolt... what do yall think?
Old Apr 26, 2002 | 06:30 PM
briansgi's Avatar
The parts illustration did not list it's size but chances are it's metric. Maybe just measure the hole and run to the hardware store and buy a short bolt, you should be able to get the right one, might have to buy a couple to make sure you get the correct thread and bolt size.
The drain bolt part number is:
593-5000920
Old Apr 27, 2002 | 01:00 PM
lonestarbanshee's Avatar
Hey.. I dunno if you've realized it or not, but Hardy's Auto Parts carries alot of the bolts I need. They had everything I wanted when I rebuilt my R. Go back with some blue loctite and a bolt. You could always stick a tampon in it and hope for the best..
toonces
Jul 23, 2015 02:21 PM
skeets44
Jul 17, 2015 01:04 PM
Desimation2k8
Jul 17, 2015 12:37 AM
Unzzy66
Jul 11, 2015 10:01 PM
Shifts
Jul 3, 2015 07:59 AM
